Kitchenaid superba slide in,no display when plugged in
hi gene, i think its great how you pass on your valuable knowledge. I bought 3 used kitchenaid appliances from a friend. dishwasher seems to work ok, side by side works nice except does not dispense ice,(will get to that later).the slide in range is not hooked up yet because he told me after self clean cycle ran it stopped working.(he had that repaired once before). its in my garage still with a oven door that wont open. According to a lot of websites, buying kitchenaid might not have been a good move. anyway with that said, i plugged it in to see what i got for error code, but the display does not light up. the outlet works because igniter sparks. tried holding the start ,unlock for 10 sec. nothing. i manage to fix a lot of things so with your help i know i’ll have this up and running. is my next step getting into control panel?
The model number is: KGSA906PSS00
Thanks!
Twospot
[RIGHT]Model Number: KGSA906PSSOO Brand: Kitchen Aid Age: 5 - 10 years [/RIGHT]
SAME PROBLEM WIFE IS PISSED !!! HELP the slide in range is not hooked up yet because he told me after self clean cycle ran it stopped working.(he had that repaired once before). its in my garage still with a oven door that wont open. According to a lot of websites, buying kitchenaid might not have been a good move. anyway with that said, i plugged it in to see what i got for error code, but the display does not light up. the outlet works because igniter sparks. tried holding the start ,unlock for 10 sec. nothing. i manage to fix a lot of things so with your help i know i’ll have this up and running. is my next step getting into control panel?
Thanks!
Henry,
You may want to check the control thermal switch for continuity first. It’s located behind the control panel. The instructions are attached top the reply.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KGSA906PSS00 30`` Slide-In GAS OVEN CONVECTION | AppliancePartsPros.com
Removing the control panel.pdf (114.3 KB)
The control and cooling fan thermal switches.pdf (53.6 KB)
