The dispensers work. The bulb works in other fixtures. Think it’s the plague of the breaking wires at the bottom of the freezer door?
What is the complete model number of the refrigerator?
k5bp25fkss00 Model Number
SMo439482 Serial Number
Thanks!
Visually inspect the bottom freezer door harness.
More likely the problem is a bad dispenser light switch (where the blue/black and the yellow/black wires are connected to).
The disassembly instructions are attached to the reply.
If the switch is bad you have to order the whole front cover assembly.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KSBP25FKSS00 REFRIGERATOR | AppliancePartsPros.com
Ice and water dispenser.pdf (406.6 KB)
