Kitchenaid Superba Microwave/Oven combo
I would like to know how to get to and remove the control panel to replace a fuse in the microwave. I have already brought the microwave out enough to work in it, and have replaced the 20amp fuse, but this did not fix my “door” code.
If you are getting a “DOOR” error, you have a faulty door switch, not a fuse issue. Do you have a meter to test with? Also, you must know that microwave service can be dangerous, even if it is unplugged, due to the large capacitor in the unit that is capable of holding a charge for a long time. Knowing this, are you comfortable continuing with this repair?
