KitchenAid Superba- Finding Model Number?
I have a KitchenAid Superba Dishwasher that I bought used a year or so ago. I did not get any paperwork with it.
The control panel is going out in it (Start button will not work) so I need to order parts for it. I can not find the model number anywhere on it. It doesn’t look like the label has been removed. All I can find is the quick use description manual sticker on the inside of the door is this number:
8531654
On the side of the door there is a number stamped into it that is:
020022015
There is nothing on the kick-panel as well.
Any suggestions in find which model number this is? I can send pic as well.
Thanks!
any ideas???
Your best bet is to open up the door and see if there is a part number on the control board the look this number up on the AppliancePartsPros website.
You may want to try the following, especially f there are 4 or 4 keys that do not work. Most keypads/control panels use certain pinouts/tracks as common to a number of keys.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector. Use electronics contact cleaner or isopropyl alcohol.
