KitchenAid stopped runnning during operation
The door handle latch broke on Thanksgiving. I removed broken pieces and it still worked. Will need to order one spring and new handle. Last night it stopped working. Not a breaker problem, checked and it had not popped. It’s hard wired, not plugable. Don’t see any burnt wires in the control panel. No lights come on. Still has some water in the bottom. Any suggestions? Related to the handle issue?
Replacement parts for KUDi01iLBSO models | AppliancePartsPros.com
My first guess would be that the latch is not closing the door switch since you have latch problems.
Next perhaps the thermal fuse (item 6 in Section 2) has blown.
Be sure to use the new harness that comes with the fuse.
The following manual should help with the repair
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/4e8b0d2df77cd7e585256cd800643b6d/$FILE/KD01.pdf
Exactly what I needed. After pulling the fuse assembly, you could see the difference in the color. Once I got that replaced and the other broken parts in, it is up and running. The shipping of the parts took a little while to all get here due to back orders, but it was only one low cost for all of them together, what a deal. Thanks!
