Kitchenaid stopped dead mid-cycle
The diswasher stopped mid-cycle (at night) and left water in the bottom of the tub. There are no lights being displayed at all. The unit just seemed to die. I checked the power connection to the unit below and confirmed that there is power to the unit. The door switch has continuity and there is no visible sign of damage to the control board. Is there a reset switch or fuse in the unit? I can’t seem to find any reference to one in the Service Manual or on the unit. Could it be the controller panel itself? The Service manual suggests to check for 1120VAC between P8 and P3 if the dishwasher will not drain. How do you do that? I says that if the power is not there, the control panel is inoerable. Can it be done from the panel? I can’t seem to find a reference that indicates which circuit is which in the wiring harness. Any thoughts before I call the man? Thanks.
Replacement parts for WHIRLPOOL KUDR01TJBL0 Undercounter Dishwasher | AppliancePartsPros.com
Take a look at Item 6 in Section 2.
If it is b;lown be sure to use the new harness that comes with the fuse.
Thanks denman, but did you attach the correct specs? The link shows the door parts, but not the control panel or fuse. I saw on other threads that there is a fuse kit that is adjacent to the control panel with a part number of AP3178588. Is that what I need or is there another model for my dishwasher? Thanks.
I just tried the link, it works for me.
Click on “Control Panel” section and that section does open
