Kitchenaid Selectra Oven
My oven will not turn on. The top burners work fine. When I try to turn the oven on, the controls turn on and and it says the oven is on but it is not turning on or working. Any help would be very much appreciated.
Pull out the range, remove the rear panel and check the fuse (#9 on the break down diagram) for continuity.
Here are the break down diagrams for the Kitchen Aid range Model KERC500YBL0
