[quote=Norman G.;358939]Hello,
I have a 9-year-old KitchenAid range that seems to have 2 problems. About a month ago the oven wouldn’t come up to temperature. The display indicated the set temp but the oven was only lukewarm. I went to the local appliance store, described the problem and was told I had a bad bake element. They didn’t have the exact KitchenAid element but sold me a similar 1500 watt element. Sure enough, when I got it apart the old element was blistered. I installed the new element and the oven seemed to work fine for a week or so.
It was then that we noticed the oven would not turn off, even when the display was off. The only way to shut it down was to throw the breaker. We then noticed that the oven wouldn’t come back up to temperature, just like before. I was told that the control board was bad. Would a bad control board cause the element to burn out too?
Norman,
My first thought is,
You may have a shoted, damaged or pinched wire to the element.
When you say the oven stays on, does the element still glow red or is it dark and producing heat ?
If it’s just warm, not glowing red hot, I would think your wire is shorted to ground and running a constant 120 VAC through the element.
If it’s glowing red, you’d have a multitude of failures.
Does the broil element work properly ?
Hope this helps,
Basic bake circuit
L1 is supplied to the power relay board on connector P6/Black,
When you program a bake cycle the relay board closes a mini relay and supplies L1 to one side of the bake element, on the P2 terminal on the power relay board.
L2 is supplied to all the elements through the double line break relay.
When the relay board/ control activates the L1 relay to the element, at the same time it supplies 24 VDC to the relay, the relay closes and allows the L2/red 120 VAC through the relay and supplies the voltage to the other side of the element, you have 240 VAC at the element and it’s on and glowing red.
It is possible that the contacts on either or both relays shorted when the original element shorted out, but not a likely scenario.
( most shorted relays aren’t intermittent, since the unit worked OK for a couple of weeks).
When you cancel the cycle or the oven is shut off, there should be NO voltage at either wire terminal of the bake element, unless at least one relay is shorted closed, or you have a damaged wire.
Good Luck,
