Kitchenaid not running
Dishwasher no longer running… LCD panel stopped completely displaying Status Window completely a number of years ago, then it would not allow me to run any cycle but Normal (I think) and Cancel/Drain. Now lights are blinking in Status and Quick Clean up and washer will not run or drain.
Tried turning off the breaker for 15 minutes, but no change.
Do you replacing the electronic control assembly will alleviate the problems?
thanks!
This morning the dishwasher lights were not blinking and it would run the cycle under “Quick Clean up”. So… it seems the problem may be intermittent.
