KitchenAid not making any ice
Brand: KitchenAid
Model Number: KRSC503ESS01
Main Symptom: Ice maker dosent work, freezer lights dont work
What happens & when: Ice maker dosent work, but all modules work in diag mode
Parts or tests already tried: repaired couple broken wires at bottom hinge
First of all let me say im new here and oh so happy to have found this forum :slight_smile:
Now, got this used and free, tought is gonna be a nice upgrade over my 20 year old one , now im not so sure :slight_smile: Brought it home and fixed the wires around the bottom hinge. Plugged it in and ever since been trying to find why it is not making any ice, but all modules work in diag mode.
Test 44 [will check again] blinks 02, I iniate goes to 01, 12 then 22. I can hear the ice tray moving, I can see it moving if door is open
Test 45 blinks 02, I iniate, goes 01, 02, 03, 02 I can hear the ice tray filling with water, I can see it filling if door is open
Test 47 is 11
Test 48 is 02 no matter what.
Also noticed that lights in freezer do not work, the only one that does ironically is the ones above the ice cube tray.
Info about wiring diagram and diagnostic codes here https://s3.amazonaws.com/sm-backend-production-attachments/wiring-sheet-W10751694-RevA.pdf
Any help would be great, thanks!
Edit 1: fixed grammar.
Edit 2: fridge started making ice. Tried 2 things 1. Changed ice type in dispenser from crushed to cubes. 2. Via the diag menu filled the ice cube tray with water and left it alone. It auto dumped the ice, flipped and filled with water by itself and continued to produce ice.
That update is actually very encouraging. Based on what you found, I would not replace the ice maker or control board right now.
Your diagnostic results show the important parts of the ice system are capable of working:
  • Test 44: The ice maker motor/tray moves during the harvest test.
  • Test 45: The ice maker successfully fills with water.
  • Test 47 = 11: Nothing there immediately points me toward a failed ice maker.
  • Most importantly, after you manually filled the mold, it froze, harvested automatically, refilled itself, and continued making ice. That proves the ice maker can operate normally outside of the individual diagnostic tests.
The part that still catches my attention is the freezer lighting combined with the broken wires you found at the bottom hinge. On these Whirlpool/KitchenAid side-by-sides, that hinge harness is worth inspecting very carefully. One repaired wire doesn’t necessarily mean the rest are healthy. A wire can be broken internally with the insulation still looking intact, and several wires can fatigue in the same area.
I would gently flex and inspect the harness for a few inches on both sides of the hinge bend, and tug each wire individually. If possible, continuity-test any questionable wires while moving the harness. Since the freezer lights are still out, there’s definitely still something to diagnose there.
As for changing the dispenser from crushed to cubed, I doubt that was what actually “fixed” the ice maker. More likely, running the fill/harvest tests got the system back into a normal operating sequence—or the original hinge-wire repair restored enough of the circuit and the ice maker simply needed time to complete its first normal cycle.
For now, I’d leave the ice maker alone and see whether it continues producing ice for the next 24 hours. If it keeps harvesting and refilling automatically, the ice-making problem is essentially resolved. Then I’d concentrate separately on the freezer lights and that door/hinge wiring.
If the ice maker quits again, tell me what Test 44, 47, and 48 show at that exact time, especially Test 48. That should give us a much better indication of what’s preventing the automatic cycle.
Hey thanks so much for responding!
Ice maker has been going strong since I posted the question.
Out of all the harness wires, only 2 seemed to be in-tact, the rest of them i fixed.
Now the only thing that dosent work is the freezer lights. Where do I begin to diagnose those?
Thanks for the info and help once again!
Yes sorry for the delay in getting back to you. Glad to hear the icemaker is going strong. That wiring issue is a fairly common problem. Let me see what I can find on the lighting system
Since nearly every wire in that bottom hinge harness was broken, I’d start there for the freezer lights too. I wouldn’t order any parts yet.
The quickest check is the freezer door switch. With the freezer door open, press and hold the door switch closed. See whether the freezer lights come on or even flicker. Also watch the control/display to make sure it recognizes the door as closed.
If nothing changes, go back to your repaired hinge harness. Since only two wires survived intact, there’s a good chance either one repair isn’t making good electrical contact or another wire is broken just above/below the visible flex point. With the refrigerator unplugged, gently tug each repaired wire and inspect farther up the harness.
Next, if you have a multimeter, we can narrow this down pretty quickly. Don’t start probing random wires with power connected. The LED lighting circuit is controlled electronically, and shorting the wrong wires can damage the control.
One other clue is important: you said the lights above the ice bin still work. That tells us this probably isn’t simply “the refrigerator has lost all freezer lighting power.” It points more toward the particular LED circuit/module, wiring, or door-switch signal feeding the remaining freezer lights.
If you tell me which freezer lights are dead—ceiling, side wall, lower light, etc.—I can walk you through the exact next meter check on the KRSC503ESS01, including which connector/wires to test
wiring-sheet-W10751694-RevA.pdf (790.0 KB)
service-pointer-w11691025-revb.pdf (1.4 MB)
Thank you.
Yes I do have a multimeter
The top and side lights are out, I think there is only the 2 of them freezer side.
Repaired wires look good, but I might have shorted something while repairing them.
Everything seems to work, besides the 2 led lights inside (top and side), it shows when door is open.
