KitchenAid Noisy Door
My 8 months old KitchenAid dishwasher is making an unpleasant noise when I open/close the door. I made a service call few weeks ago when the problem started. A technician from Whirlpool came and simply sprayed liquid grease on the lanyards and pulleys. It’s was quiet for about 2 weeks.
Now I don’t want to pull the dishwasher every few weeks to put more grease. I searched the web and I found this: http://appliancejunk.com/forums/index.php?topic=2123.0
It seems like Whirlpool is now making a door balance kit with two pulleys.
I called Whirlpool again to get this new door balance kit installed as it would fix the problem permanently. Sadly, they don’t have access to that kit which I find pretty strange.
So I want to order this kit from the net and install it by myself. So I would like to know where to order the part from ? AppliancePartsPros doesn’t have the new version of the kit with the two pulleys.
[quote=Westbank;82746]Hi,
Thanks[/quote]
The link below has this part in stock
http://www.************************.com/SSPartDetail.aspx?s=t-8194001-%3d%3di1059756&PartID=1059756
Hope this helps!
Iceman
http://www.************************…PartID=1059756
Hope this helps!
Iceman
IceMan309
It seems like the link is censored ? Everything between www and com is a bunch of asterisk.
Iceman309
I finally figured out the url. The kit on that site is identical to what I have right now. It only has one pulley at the bottom and not two.
Did the page offer the 1059756 kit? It shows 2 pullleys and 2 lanyards. I understood this to be the new kit from the link that I found.
Do you need me to help you more with this issue?
Iceman
