KitchenAid Microwave blowing fuse
Brand:KitchenAid
Model Number:KHMS2056SSS-3
Main Symptom:blows fuse and trips circut
What happens & when:Door is pened or closed
Parts or tests already tried:replaced fuse
Jblake9000, thanks for your post. Since the fuse is blowing whether the door is open or closed, that strongly points to a door switch failure, and there may possibly be a secondary component that has also failed.
Do you have access to a multimeter? If so, we can run a couple of quick tests to help narrow down exactly which part is causing the issue.
