KitchenAid lights blink, runs 10 sec, quits
DIshwasher set lights blink when you push them and then go out. When you run it, a 10 sec countdown starts and you hear the motor run. THen it quits.
Hi.
Remove the control panel, disconnect the ribbon flex connector. Using the pencil eraser clean the end of the ribbon where the contacts are. reconnect and try.
If it still doesn’t work - replace the control panel.
The control panel (black) [PART]AP3177372[/PART]
The control panel (white) [PART]AP3177373 [/PART]
Here are the breakdown diagrams and Replacement parts for Whirlpool KUDS01ILBT0 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
Thank you. Post the results.
Simon.
