As stated I press the normal mode button, light comes on, press start and close the door and nothing,
Happened last week and I turned the breaker off for 5 minutes and it started again.
Happened again today and the breaker trick didn’t work. Took it apart and nothing stood out..
Have read quite a bit and apparently the lights are supposed to flash when I press the start button, I don’t remember them doing that, but they might have and they don’t now.
Put it all back together, powered back up… used my fingernail to press the startbutton and wiggle it a bit and I believe the light flashed, shut door and it started. Would that be the ‘user interface’ that needs replacing?
User Interface
by Whirlpool
Part Number AP6012912
Seems like it is a button problem… if the thermal fuse was gone it wouldn’t start at all I assume. Damn user interface is $198! seems like a lot, but as long as it works… Can anyone confirm this sounds right (or wrong) to them? thanks ![]()
