On the KitchenAid KSSS48QMB01, the blinking red OVER TEMPERATURE RESET light is not usually the actual failure. It means the refrigerator/freezer got too warm. KitchenAid says the alarm occurs until the freezer gets below about 15°F and refrigerator below 48°F.
Since yours is not cooling, I’d diagnose the cooling system rather than concentrating on the reset light.
Start here — top machine compartment
Remove the upper grille and check the refrigeration components while the unit is calling for cooling.
You should normally have:
- Condenser fan running
- Compressor running
- Warm/hot condenser tubing
- Evaporator fan running inside the freezer when appropriate
This model uses an inverter-driven compressor, so don’t treat it like a conventional refrigerator with a simple start relay. The service information specifically lists the main control, inverter, compressor, and inverter control wiring when the condenser fan operates but the compressor doesn’t.
Quick diagnosis
1. Is the condenser fan running?
If NO, verify incoming power and whether the refrigerator is actually calling for cooling. That moves the main control/power supply higher on the list.
If YES, immediately check the compressor.
2. Is the compressor running?
Put your hand on it. You should feel a steady vibration/hum.
Condenser fan ON + compressor OFF is an important condition on this machine. Suspect:
Main control → inverter/control wiring → inverter → compressor.
Don’t automatically replace the compressor just because it isn’t running.
If compressor IS running
Let it run 15–20 minutes and inspect the freezer evaporator frost pattern.
You want a light, fairly even frost pattern across most of the evaporator.
If you get:
- Heavy snow/ice covering the entire evaporator: likely defrost/airflow problem.
- Frost only on the first few passes: likely sealed-system problem—low refrigerant/restriction/weak compressor.
- No frost at all with compressor definitely running: strong sealed-system/compressor suspicion.
- Good frost pattern but poor temperatures: concentrate on evaporator fan and airflow.
Common no-cooling causes listed for this exact model include compressor problems, condenser/evaporator fan failures, control problems and sealed-system failures.
If freezer gets cold but refrigerator doesn’t
That’s a different diagnostic path. Check the evaporator fan, air door/damper, air returns and refrigerator thermistor. The service information specifically points to those components for a warm refrigerator compartment.
Reset the red light
Press OVER TEMPERATURE RESET to acknowledge the alarm. You can also shut the refrigerator off at the breaker for 5 minutes, restore power and monitor it. But if the cooling failure remains, the temperature alarm will return.
The quickest next question is: when you open the upper machine compartment, is the condenser fan running, and is the compressor running/vibrating?
If you tell me fan YES/NO and compressor YES/NO, I can take you directly to the inverter/compressor voltage tests for this KSSS48QMB01.
