KitchenAid KSC25INSS01
This is driving me nuts!
I’ve replaced the evaporator temp sensor, and then the evaporator fan, as the unit wasn’t cooling.
Now it’s cooling just fine with 0 in the freezer side, and 38 in the refrigerator side, BUT:
Both the compressor fan and the evaporator fan almost always continue to start and stop nearly all the time, so I know something is eventually going to quit entirely, and it’s loud enough that I can hear it at night when the house is quiet.
What could be going on? Should it be cycling like that?
KKellyNC, thank you for your question. The fans should not be cycling on and off continuously and this would be a failure within the main control if the compressor does not cycle like this. Unfortunately, the main control W10219463 has been discontinued by the manufacturer and is no longer available.
