KitchenAid KODE900HSS00 Display Dark
Brand: KitchenAid
Model Number: KODE900HSS00
Main Symptom: Display Dark
What happens & when: Noticed display dead and flickering every 30sec or so, buttons of panel unresponsive, however the lights within the oven still turn on when doors are open. This started shortly after several power outages related to weather, during which we did use a generator
Error Code (if any): n/a
Parts or tests already tried: Attempted to replace Whirlpool Wall Oven Electronic Control Board OEM Part Number W11294389 without change
That’s going to be an issue with the control panel W11399172.
https://www.appliancepartspros.com/whirlpool-console-w11399172-ap6977334.html
Awesome thank you so much. Will look into that part.
