Brand:Kitchenaid Model Number:KFCO22EVBL1 Main Symptom:Replacement control boards do not come out of programming mode What happens & when:
Error Code (if any):none board just flashes PE
Parts or tests already tried: Have tried 3 WPW10116216 replacement boards (order# 17165477)
Have tried 3 replacement control boards and all 3 stay in programming mode (displays flashing PE and 000 where the code 01 should be) when power is restored. The overlay keypad buttons does not seem to work or change any values. I have ensured both the ribbon cable and power cable are secured in place and have tried several times of shutting the power off for 10 minutes intervals with no impact or success. Have also reviewed and tried the programming instructions to place the control board in programming mode and exit programming mode but the overlay buttons do not respond even holding them for 15 seconds. Hoping you can help provide some insights. Thanks
The display already is displaying PE when the power is restored to the fridge. I have tried using the keys like you have suggested, however, there is no response or changes and the board keeps flashing PE. I have also tried exiting by pressing the Door Alarm key for several seconds and still no response.
Any suggestions on where to find a replacement Overlay? The mfg states it is no longer available. Would another overly from a different model work? I found this one on your site and it looks very similar Whirlpool WPW10317125. Your thoughts?
