KitchenAid Kerc607gwh1 elements not heating up
Please someone help me… the oven heatin element are not heating at all! when control panel is stuck in “LO” no electric juice is going up from relay to mother board. How about the FUSE? Heat Sensor is good; Oven, Broil and hidden elements all working too. Stove working fine.
:frowning: :frowning: :frowning: Please help!
[QUOTE=CPA;466589]…the oven heatin element are not heating at all!
…Oven, Broil and hidden elements all working too…[/QUOTE]
I’m confused. Can you describe more detailed what is working and what is not?
Stove working/fun working … but not the oven no heat at all. It will start up to heating degree then it will stay in “LO”. It’s the IN-Line Fuse not working.
Locate the DLB relay (#30 on the diagram). Measure the coil resistance. The normal reading should be about 4100 Ohms. If the reading is incorrect, replace the relay.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KERC607GWH1 30" FREESTANDING CONVECTION OVEN | AppliancePartsPros.com
