Brand: Kitchenaid
Model Number: KDTM604KPS1
Main Symptom: Display lights erratic and beeping
What happens & when: Randomly over past two weeks
Error Code (if any): No error code , but typically 3 lines blinking.
Parts or tests already tried: I have reset machine with hard power off, checked for water in plastic reservoir for and float switch created problems. door switch seems fine. It will also occasionally jump between modes such as normal wash and express wash, etc. Also will occasionally adjust time from default. Ex. Normal 2:45 wash changes to 3:08. I suspect a main control board issue.
