KitchenAid KDTM604kps Not spraying
Brand: KitchenAid
Model Number: KDTM604kps2
Main Symptom: Not spraying/Recirculating pump not working
What happens & when: All cycles
Error Code (if any):None
Dishwasher runs through cycle with no error code but does not spray. Fills and empties fine. Never hear any motor hum or click to indicate it is trying to start. I enter diagnostic mode and all lights come on but no diagnostics are completed. I am thinking it is a control board problem?
If you have a multimeter available, there is a test that can be done at the motor. Setting the meter to Volts AC and placing a probe into each light blue wire, a cycle can be started. After 2 minutes, there should be 120 Volts AC reaching the motor. Is the voltage present or is it not there after the two minutes?
Thank you for the help. It does read 120v after a min when I tried this. Probably the pump motor?
The circulation pump would certainly be an issue since it is receiving voltage and is not operating. From what I am able to find, this would be the circulation pump used with your model. W11414076 Circulation Pump | Genuine Whirlpool OEM In Stock
Thanks, I’ll give it a try.
