KitchenAid KDTM354DSS4 Hinge Broken
Brand:KitchenAid
Model Number:KDTM354DSS4
Main Symptom:Right hinge broken
What happens & when: When you open the door, there is a loud clunking sound. I’ve taken it apart and the hinge component attached to the door seems fine but the pin that it rotates on is broken. It seems like the pin is attached to the tub so I’m wondering if it is replaceable. If so, what is the part called? I wasn’t able to find anything in the parts diagram that I thought was the correct part.
Unfortunately, the pins are part of the cabinet and is not a repairable part without getting the tub.
https://www.appliancepartspros.com/whirlpool-tub-dishwr-w10681507-ap5971937.html
