For your KitchenAid dishwasher KDFM404KPS0, I wouldn’t replace the control board just yet.
The F9E1 error indicates a long-drain condition, meaning the control isn’t detecting that the dishwasher has drained properly within the expected time.
Since you manually filled the dishwasher and it drained successfully, that’s a good sign. It tells us the drain pump is capable of moving water, but it doesn’t necessarily mean the dishwasher is recognizing that the water has drained.
I’d concentrate on the water-level sensing system, drain pump operation during a normal cycle, and wiring before suspecting the control board.
Here’s what I’d check next
1. Check for water remaining in the sump. After the dishwasher drains, look down into the sump area. A small amount of water below the filter is normal, but there shouldn’t be standing water above the sump floor.
2. Check the pressure sensor and its opening. This model uses a pressure-sensing system to monitor water level. Food residue, grease, or debris around the sensing port can cause an incorrect water-level reading even when the drain pump works.
3. Watch what happens when starting a normal cycle. Does the drain pump run immediately, does the dishwasher fill with water, or does it display F9E1 before either operation? That distinction will help narrow down the problem.
4. Inspect the connections. With power disconnected, check the pressure sensor and drain pump wiring for loose connectors, corrosion, or damaged wires.
One additional test
Disconnect the dishwasher drain hose from the garbage disposal or sink drain and direct it into a bucket. Run the drain function again.
If you get a strong, steady stream of water, that helps rule out a restriction in the dishwasher’s drain path. Also check the disposal connection and make sure water isn’t flowing back into the dishwasher.
If the pump drains strongly, the sump is clear, and F9E1 keeps returning, I’d investigate the pressure sensor circuit before replacing the main control board.
Two questions that will help narrow this down:
When you start a normal wash cycle, does the dishwasher actually fill and begin washing, or does it immediately display F9E1?
When you manually fill it and run the drain, does it completely empty the tub and then display F9E1, or does that particular test finish without an error?
Those answers will help determine whether we’re dealing with a drain-command problem, an incorrect water-level reading, or possibly the control board.
