KitchenAid KCMS2255BSS Microwave Control Board Replacement Instructions
Brand: Kitchen-Aid
Model Number: KCMS2255BSS
Main Symptom: Segments of the control panel LED display not working.
Solution: Replace Control Board
I could not find disassembly / reassembly instructions online, so I created a quick guide to help others.
KitchenAid KCMS2255BSS-0 / KCMS2255BSS-1 Microwave Control Board Replacement Instructions
Repair: Replacing the microwave control board and restoring a faulty LED display
These instructions apply specifically to the in-wall-mounted KitchenAid KCMS2255BSS-0 and KCMS2255BSS-1 microwave models.
The Problem
My KitchenAid microwave developed a display problem where individual segments of the LED clock display stopped working. The microwave itself continued to operate, but portions of the numbers were missing.
I located a replacement control board on eBay. However, I could not find any online instructions or videos that accurately described how to remove the microwave and access the control board for these specific models.
The following instructions document the process I used to access and replace the control board.
Tools Needed
  • Phillips screwdriver
  • Torx screwdriver or bit set
  • Replacement microwave control board
  • Camera or smartphone to photograph wiring connections
Control Board Replacement Procedure
Step 1 – Disconnect electrical power
Turn off the circuit breaker supplying power to the microwave.
Step 2 – Remove the stainless-steel trim plate
Remove the four screws securing the trim plate to the cabinetry:
  • Two screws at the top.
  • Two screws at the bottom.
The screws enter at approximately a 45-degree angle.
Remove the trim plate and set it aside.
Step 3 – Remove the microwave mounting screws
Remove the four screws securing the microwave inside the wall enclosure:
  • Two screws on the left mounting rail.
  • Two screws on the right mounting rail.
Step 4 – Slide the microwave out
Carefully slide the microwave straight out of the wall enclosure.
Have someone assist you and unplug the microwave from the wall outlet once it is accessible.
Step 5 – Remove the microwave outer shell
Remove all Torx screws securing the rear of the microwave.
The sides of the outer shell will flare outward slightly. The entire shell then slides toward the rear of the microwave. Some pulling may be necessary to release it.
IMPORTANT SAFETY WARNING: Microwave capacitors can retain potentially lethal electrical charges even after the appliance has been unplugged. Opening the outer shell exposes internal high-voltage components. Accessing and replacing the control board should only be performed by someone qualified to work safely on microwave electronics. Do not touch or attempt to discharge the high-voltage components.
Step 6 – Locate the control board
With the outer shell removed, the control board will be visible attached to the control panel assembly.
Step 7 – Remove the control panel
There is one Phillips-head screw securing the control panel in place.
Remove this screw. The control panel will slide upward slightly and then come out through the front of the microwave.
Step 8 – Disconnect the wiring
Disconnect the electrical wires connected to the control panel.
Pay close attention to where each wire connects. Take photographs before disconnecting anything to make reassembly easier.
Step 9 – Remove the control board
Remove the three screws securing the control board to the control panel assembly.
Release the ribbon cable by lifting its connector locking mechanism and carefully withdrawing the ribbon cable.
Remove the old control board.
Step 10 – Install the replacement control board
Position the replacement board onto the control panel assembly.
Reconnect the ribbon cable, ensuring it is fully seated and its locking mechanism is secured.
Reinstall the three mounting screws.
Reconnect the remaining wiring using your photographs as a reference.
Step 11 – Reassemble the microwave
Reverse the disassembly procedure:
  1. Reinstall the control panel.
  2. Reinstall its Phillips-head mounting screw.
  3. Reinstall the outer microwave shell and Torx screws.
  4. Have a qualified person complete any required internal safety checks before reconnecting power.
  5. Reinstall the microwave into the wall enclosure.
  6. Reconnect the power cord.
  7. Reinstall the four microwave mounting screws.
  8. Reinstall the stainless-steel trim plate using its four screws.
Verify proper operation after reassembly.
Final Notes
These instructions are based on my actual experience replacing the control board on a built-in KitchenAid KCMS2255BSS microwave.
I could not find repair videos or online instructions that matched these specific models, so I’m sharing this procedure to help other owners who experience the same LED display failure.
Applicable models:
  • KitchenAid KCMS2255BSS-0
  • KitchenAid KCMS2255BSS-1
Original symptom: Missing segments in the LED clock display.
Replacement component: Microwave control board (replacement sourced through eBay).
Hopefully, this saves someone else the time and frustration of trying to find repair instructions for these particular models.
