Under counter unit makes ice fine but when bin gets full, unit does not stop. I checked thermostat at bin and resistance seemed to be in range. I measured 18 kohms at room tempt and 32 ohms in glass of ice water. I concluded pc board was bad so I ordered a new board. When I installed new board the problem was the same. Unit works but does not quit when bin gets full. What else should I try? Any Ideas?![]()
I hope this Service manual will help you.
Here are the break down diagrams for the Kitchen Aid icemaker Model KUIS18NNJB8
I know it’s been a long time, but do you still have the service manual for this icemaker? the link no longer works.
Thanks,
MAx
