Kitchenaid ice dispenser does not work
I have a kitchenaid side-by-side with an in-door ice dispenser which is not working. The water dispenser and light work. The ice dispenser door also operates. The ice dispenser motor does not even attempt to operate. The wiring harness comes in from the top hinge, and does not appear to be damaged. Is there some diagnostic I can do to check the ice dispenser motor or control panel?
You have to check the ice dispenser motor first. The instructions are attached to the reply.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KSRS25ILSS02 REFRIGERATOR | AppliancePartsPros.com
In-door ice system - Removing the ice maker.pdf (304.8 KB)
Troubleshooting the motor (in-door ice).pdf (252.9 KB)
