Kitchenaid hand mixer
I have a Kitchenaid hand mixer, model KHM3WH, Serial # WMX47. It is approximately 10-15 years old and still works great except that the beaters keep falling out. Is there a way to fix this or is it just worn?
Thank you:rolleyes:
Roger P
[QUOTE=Roger P;67049]I have a Kitchenaid hand mixer, model KHM3WH, Serial # WMX47. It is approximately 10-15 years old and still works great except that the beaters keep falling out. Is there a way to fix this or is it just worn?
Thank you:rolleyes:
Roger P[/QUOTE]
I have the same problem of the beaters falling out. It seems to be frequent problem with these mixers. Is a replacement gripper part available to fix the problem and if so, how easy is this to replace?
