Kitchenaid Fridge
Center divider strip between doors is extremely hot. Unit cooling fine on both sides but runs almost continually. Cleaned coils per directions in manual best I could, no help.
Did you check that the condenser/compressor fan was running.
And that it is blowing correctly.
I would also check the fan blades as dirty blades can drastically reduce air flow.
Also check that the rear cover vents and the kick plate vents are clean.
read this: How to Fix a Whirlpool & KitchenAid W10219463 / 2307028 Control Board for $6 - SteveJenkins.com
If you’re handy with a screwdriver & soldering iron, you can fix it yourself – I did.
