Kitchenaid Fridge Light Not Working
I have a Kitchenaid refrigerator (KSCS23INSS01) and the top shelf lights on the fridge side will not work. I tried new bulbs, but didn’t work. Lower down in fridge side there’s another light that goes on fine. The freezer lights work fine. The lights on the water/ice dispenser work fine. It’s just the top two bulbs on the fridge side that are not working. Both went out about 6 months ago and I was able to get one replacement bulb to work (the other socket didn’t work after that). Now, both sockets will not work with new bulbs.
Any thoughts? Thanks.
Hi.
With the fridge unplugged check the contacts inside the light
socket 4387478
Here are the breakdown diagrams and Replacement parts for Whirlpool KSCS23INSS01 REFRIGERATOR | AppliancePartsPros.com
Thank you. Post the results.
Simon.
[QUOTE=RowRow;757507]I have a Kitchenaid refrigerator (KSCS23INSS01) and the top shelf lights on the fridge side will not work. I tried new bulbs, but didn’t work. Lower down in fridge side there’s another light that goes on fine. The freezer lights work fine. The lights on the water/ice dispenser work fine. It’s just the top two bulbs on the fridge side that are not working. Both went out about 6 months ago and I was able to get one replacement bulb to work (the other socket didn’t work after that). Now, both sockets will not work with new bulbs.
Any thoughts? Thanks.[/QUOTE]
Hi there,
I realize this is an old post, but I’m in the same situation and wondering whether you found a solution?
Any advise would be much appriciated.
You can contact to service center and they are solve your problem properly.
