Kitchenaid fridge KSCS23INSS00
Brand: Kitchenaid
Model Number: Kscs23INSS00
Main Symptom: Condensor fan very short cycles
Based on the description of the issue check to see if the condenser fan motor has constant power to it when it should be running ( it should be running any time the compressor is running. If there is a loss of power to the fan check the wiring for loose connections and if the wiring is good this could be a control issue. If there is power to the fan and it is not running then the fan would need to be replaced.
