KitchenAid fridge door clicks after replacing cams
Brand: KitchenAid
Model Number: KSRB25FHBT02
Main Symptom: Door clicks
What happens & when: Since replacing the cams, the right side door clicks when opening
I replaced the upper & lower door cams as the old ones were worn and the doors were no longer closing without aid. Since replacing AP6019682 and AP6005980, the door clicks.
The door hadn’t clicked before replacing the cams.
I checked for and found no obstructions that might explain the sound.
The freezer door seems fine.
Any ideas appreciated.
Since the clicking started right after replacing the door cams, I would suspect something with the new cams or their alignment rather than an obstruction.
The cams work together to help the refrigerator door close on its own. As the door opens, one cam rides up over the other. If they aren’t lined up correctly, they can make a clicking or popping sound.
Here are a few things I would check:
1. Check the cam alignment. Make sure both cams are fully seated, installed in the correct orientation, and securely fastened. Even a slight misalignment can cause a clicking sound as the cams move against each other.
2. Check the door height. Compare the refrigerator door’s height and alignment with the freezer door. If the refrigerator door is sitting a little too low, the cams may not be engaging correctly. Check for any missing washers or spacers around the hinge.
3. Inspect the new cams. Look for any rough edges, raised plastic, or signs that the cams are catching as the door opens. Also, make sure the replacement cams match the originals in shape and mounting position.
4. Check the hinge screws. Make sure the lower hinge is tight and hasn’t shifted. A loose or slightly misaligned hinge can cause the cams to snap against each other.
One thing I’d like you to try is slowly opening the refrigerator door while watching the lower hinge and cams. See whether the clicking happens right when one cam starts riding up over the other.
I also have two questions:
  • Does the door click just once as you open it, or does it click several times?
  • Since replacing the cams, does the refrigerator door now close on its own as it should?
Those answers should help us determine whether we’re dealing with normal cam engagement, an alignment issue, or a problem with one of the replacement cams.
I wouldn’t order any additional parts just yet. Since the clicking wasn’t there before the repair, I’d concentrate on the cam installation first.
