Kitchenaid free standing ice maker not cold enough
Brand:Kitchenaid
Model Number:KUIX535HPS
Main Symptom:melting ice
What happens & when: produces ice but seems like maybe inside isn’t cold enough as pump has to run frequently to pump water into the drain from the ice melting inside unit. What should the internal temp be and is there a way to make it colder.
Error Code (if any): none
Parts or tests already tried: replaced the pump as it was faulty
The ice production mode should stop once the bin thermistor identifies the internal temperature being less than 37 degrees. As the internal temperature is reliant on the ice produced, there would not be a way of making the internal temperature colder than the ice can make it. However, if the external drain pump is operating more than normal, the door seal can be inspected to identify if there is an air leak. A dollar bill or equally sized paper can be placed between the door gasket and the ice compartment. With the door closed, slowly pull the dollar/paper out and repeat this process across the entire gasket. If there is no resistance at any point, warm air could be leaking in at that point and causing the ice to melt faster than normal. WP2217294 Door Gasket (15-Inch) | Genuine Whirlpool OEM In Stock
