Brand: KitchenAid
Model Number: KDFE104HPS
Main Symptom: Not getting water into it
What happens & when: Unit inadvertently run with no water after an unrelated kitchen sink repair. Water supply was restored, verified and unit started again with same result. Water was added manually as necessary and the DW successfully completed the cleaning cycle, draining properly. What part(s) could have been damaged by running the DW with no water through a complete wash cycle? Is there any to test said part(s) without removing the DW from under the kitchen counter?
