Brand:Kitchenaid
Model Number:KODE900HBS00
Main Symptom: Controls frozen. Display flashes at times.
What happens & when: The electric double wall oven was functional perfectly. Out of nowhere with no obvious cause or power outages, the display was found to be flashing between nothing, and the “kitchenaid” logo. The oven lights illuminate normally with door open / close function. It will not accept any button input. Pressing the functional buttons or touch screen results in no changes. Breaker has been reset and also left off overnight with no remedy. Opening the access panels, there are no obvious fuses to replace or reset. It seems like I need the main control board- but would like to ask a pro before throwing parts at it.
Error Code (if any):No error codes
Parts or tests already tried: visually, no obvious fuses to replace. power cycled many times.
