Kitchen aid Double oven. Top oven will not heat. I just replaced the igniter and no luck.
About 4 years ago similar issue but new igniter worked.
Bottom works like a champ.
Temp lights up as Lo, but doesn’t heat.
Model#?
Some model# helps…
Does the igniter come on?
jeff sr.
Greetings Jeff.
Model #KGRS505XBL04. Ignitor will not light. It was out of the box.
The power for the igniter goes through the gas safety valve. Take a picture before removing any wires.
jeff sr.
