I have had this dishwasher for 2 1/2 years and now has broken for the second time. Once at 1 1/2 years, of course out of warranty. The soap door would not open at that point, now the “Normal” button will not work. The other buttons seem to work but the dishwasher just shuts off after a minute or so. Any ideas?
Here are the parts
Replacement parts for WHIRLPOOL KUDK02CRBS3 | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%20W10082651.pdf
The Normal key not working could be just the keypad.
The tech sheet show how to check it with a meter.
Try the connector cleaning shown below.
The stopping during the cycle on the other cycle options is more perplexing.
Sounds like the unit is waiting for a signal input and either is not receiving it or interpreting it incorrectly.
Try running the diagnostics to narrow it down.
Connector Cleaning
Unplug the unit
Open it up
Clean the edge connector.
Thanks. Funny thing is…after looking at all the dishes I had to do. I tried the dishwasher and it worked just fine this morning. I am not sure what is going on.
This does sound like a dirty contact/connector often this will cause an intermittent problem.
