Kitchenaid dIshwasher wont start
Dishwasher will not start. Only a couple of days ago it was still working.
After reset, poured a large pot of water and with all the lights on, I closed the door it started doing something for a few minutes, then quit. When I start a new cycle like I normally do for soiled dishes, it just won’t start. Any idea what is wrong? Thank you!
Hi.
Can you please clarify where and why you poured a large pot of water?
And also does any lights at the control panel on?
Simon.
[quote=Simon / APP Team;814762]Hi.
Simon.[/quote]
Hi, Simon - I poured water because of recommendation I found on the web. I is supposedly to “prime” the pump.
I can get all the lights to turn on all at once by pushing Hi-temp, Energy Dry, Hi-temp, Energy dry. I closed the door as soon as all the lights are on. I heard the dishwasher to start. It only last a few minutes before it shuts down. Without a pot of water, it seems light dry-run, no trace of water was found. With a pot of water, I can see splashes inside the tub.
