Kitchenaid dishwasher will not sanitize
Brand: Hello I have a kitchenmaid dishwasher model # KDFE104DBL5 I have replaced the following parts after chasing an initial failure of the diverter seal and water inlet valve:
New Main pump assembly
New Drain Pump
New Thermostat
New Control board
New Turbidity sensor
New Heating element
No codes are present after running diagnostics, the incoming water temp is well over 120 Degrees F , the heating element is active, the failure (blinking sanitize light) only occurs when a cycle using this feature is chosen. All other cycles run fine.
Any help is very much appreciated
Model Number:
Main Symptom:
Error Code (if any): no codes present
A copy:
Sanitized LED Blinks or Incomplete Sanitization Message at End of Cycle (Control Could Not Confirm Sanitization Achieved.)
Causes and checks:
  1. Door opened during
    final rinse or dry.
    Instruct customer.
  2. Incoming water
    under 84°F (29°C).
    1. Be sure dishwasher is connected to
    the hot water supply.
    2. Confirm temperature at sink
    (recommend 120°F [49°C]). Instruct
    customer to run water at sink before
    running dishwasher.
    3. Unplug dishwasher or disconnect
    power, check all connections, and
    measure resistance in Temperature
    Sensing circuit. Replace OWI if
    resistance is high.
  3. Line voltage too low to heat fast enough.
    Check power source. Confirm at least
    100 VAC.
  4. Heating problem.
  5. Refer to “Service Error Codes Table.” 7-1
  6. Intermittent door switch/latch connection.
    See same checks as for 5-1 error. Refer
  7. Thermistor/OWI problem.
    Refer to “Service Error Codes Table.” 3-1
    3-2
  8. Air pressure surging
    in dishwasher due to
    washing with high suds
    causes brief opening of
    door switch contacts
    during final rinse.
    Refer to “Service Error Codes Table.” 6-3
I found this is the tech sheet. One should be inside your dishwasher.
jeff sr.
Thanks for the reply I ended up removing the dishwasher and I re-seated all of the wire harness plugs. Then ran diagnostics no codes were present so I then ran a full wash cycle with sanitize and it worked great.
Glad that was all it was!
jeff sr.
Another sanitize cycle was attempted however this one failed to sanitize. Given the extensive list of parts that have been replaced I have ordered a wiring harness.
Keep us posted.
jeff sr.
Will do I am point the point now where I will not let this thing beat me !
Followup: I have suspected a voltage sag while under high temp stress, all along but didn’t want to take on installing a new dedicated feed to the machine. Today I installed a dedicated feed with new breaker and current code Romex. The machine ran a sanitize cycle no issues. I will run another cycle tomorrow to pressure test the repair. I figured out that the electrician had this original feed serving the washing machine and the dishwasher. The run is 30 years old and has been stressed many times at the machine moving in and out of the cabinet for repairs.
Good catch!
A copy:
Dishwasher (posted 2010) - 110 - 120 volt, 60 hertz, properly grounded circuit protected by a minimum 15 amp breaker or fuse ( d/w without temp boost ) to a maximum of 20 amp breaker or fuse ( d/w with temp boost ) #14 gauge house wire minimum for 15 amp protection, #12 gauge is a must for 20 amp protection. A separate (dedicated ) circuit serving this appliance is recommended.
Dishwasher Built in (posted 2021) - 120-volt, 60 Hz, AC-only, 15amp or 20amp, fused electrical supply, copper wire only, a time-delay fuse or circuit breaker on a separate circuit.
jeff sr.
Ran a second sanitize cycle last night (2 cycles in 2 days stress testing) and the machine completed with no issues. I am calling this one fixed.
Thankx for the update! :slight_smile:
jeff sr.
