Kitchenaid dishwasher stops multiple times midcycle
Brand:Kitchenaid
Model Number:KDTE234GPS0
Main Symptom:Stops mid-cycle
What happens & when:Sometimes makes it all the way through cycle, but often stops and must be restarted (typically restarts where it is in the cycle)
Error Code (if any):2-1 (I think)
Parts or tests already tried:I replaced the latch thinking maybe it wasn’t staying closed, but problem still happens. I have limited success when I tape the dishwasher closed (sometimes works, sometimes doesn’t)
Hello, Being you have already replaced the latch and you seem to have covered the door popping open during the cycle, that leaves the control board as a good suspect. W11305303 Electronic Control Board | Genuine Whirlpool OEM In Stock
