My dishwasher is stopping mid-cycle, about 10 minutes in, with all the lights off. I can restart it, but it stops again.
It fails in this way in ProWash mode, but will run all the way in 1-Hour-Wash mode.
Entering diagnostic mode, I get the error code 6-1.
Guessing it was the control board, I contacted KitchenAid and they sent me a new one under warranty. I replaced the board. The first load through worked fine. Woo-hoo! But, then the second load stopped mid-cycle, still with diagnostic code 6-1.
Could the new board also be bad? What else can I try?
Turns out the screen of the fill valve became partially clogged with sediment. I replaced the valve and all is good. I may have been able to clean out the screen with the same result.
I was having a similar problem. Then about 2 weeks later my water heater gave out. Once I got it replaced, the dishwasher worked fine. It had something to do with the water temperature - so just wanted to pass that along.
