Kitchenaid Dishwasher Not Running KUDS25SHWH0
I have this Kitchenaid which has been great but took a bad turn. What it is doing now is not doing anything when I start a “normal” or “short” cycle. The problem started with dishes not coming out clean. Now it just won’t run.
The lights on the control panel seems to work so I don’t think control board. I checked the check valve and it was clear.
Any clues as to what it could be? Is it time to replace? Hopefully I can get some more mileage out of it! Thank you.
How did you make out?
I am having a similar issue with my kitchenaid dishwasher. I tried checking the thermal fuse first with a multimetre and it was working. I’m now thinking it could be the control panel because the start button key pad has been broken and wondering if maybe moisture has gotten in? Any help/insight would be great.
Faizel
