Kitchenaid dishwasher not completing cycle, not draining
Brand:Kitchenaid
Model Number:KDTM404KPS0
Main Symptom:not draining
What happens & when: Dishwasher runs a cycle then near the end, around the drain cycle, it stops and beeps. then i get 9 flashing lights, pause(beep), 1 flashing light, pause(beep) and repeats. If i open door hit the Cancel/Drain button twice then close door it will then drain. I have had the dishwasher for over 5 years,m this problem just started recently.
Error Code (if any):9 flashes, pause, 1 flash, pause repeat
If the unit will drain when you push cancel drain but will not during the cycle then this will be an issue with the control board.
https://www.appliancepartspros.com/whirlpool-cntrl-elec-w11410066-ap6981327.html
I ordered, received and installed this part. Still did not solve my problem. The dishwasher seems to run its cycle, but, when it gets to the draining part at the end. I get a warning signal followed by 9 flashes, the pause, then 1 flash and pause. Any other suggestions? drain pump maybe?
It would be recommended to put the unit through a cycle and test to see if the drain pump is receiving voltage when it calls to drain. If it does then yes the drain pump would be the likely issue.
