KitchenAid Dishwasher - No Power @ Panel
Dishwasher stopped working a few weeks ago due to a faulty start switch on the control panel / user interface. All the lights were lit and the buttons would respond to input except for the start switch. Ordered a new user interface from here (part #AP3177796), swapped it out, and the machine was working like a champ again.
A few weeks later (last weekend) it stopped mid-cycle with a tub full of water. This time there were no lights, no button response, nothing at the control panel. Checked the house breaker - fine. Checked the junction box under the toe-kick - 120v fine. Ordered a replacement user interface, swapped it out today, and still nothing!
What should I be looking for / at? I read the article on continuity testing, but I’m still not sure if that’s what I should be checking on this unit for the described issue (I have a digital multi-meter). I’m a builder, so I can manage my way around most technical things, but I’m not sure where to go from here on an appliance repair. I need to get this thing running again before my kids generate any more dishes and my wife makes me sleep in the kitchen sink!
Replacement parts for WHIRLPOOL KUDP01FLBL5 Undercounter Dishwasher | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208564040.pdf
I would check the thermal fuse Item 6 in Section 2.
If you replace it be sure to also use the new harness which comes with it.
Denman,
Thanks for the advice. I checked the thermal fuse and it was blown (open / no resistance). A local shop had one on-hand so I grabbed that for the sake of making my wife happy. I swapped it out and the machine is back and running again. WooHoo! Thanks for getting me out of the doghouse.
