Kitchenaid dishwasher heater not heating
Brand: Kitchenaid
Model Number:KDTE104ESS1
Main Symptom: heating element not working
What happens & when: Checked the element and fuse and they are ok
Check to see if there is 120 vac to the heater when it is supposed to be on. If there is power but not heating then this will be a faulty heater that would need to be replaced.
So I checked the element and fuse and they are good. What next ?
If there is 120 vac to the heater but not coming on then this would be a faulty heater. If there is not power then the control board would be the issue.
