Kitchenaid Dishwasher Control Panel Won't Turn On
The dishwasher was working fine. Then the door was slammed shut. Now, the door still latches but the panel won’t turn on. Does anyone know if this sounds like it is more something with the microswitch in the latch or a fuse or something else.
You have to open the control panel and check the door switch(es) and how it’s engaged when the door is latched.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KUDS25SHBS1 | AppliancePartsPros.com
