This problem has been intermittent but it’s back! You can select the different cycles on the touch panel but when you press Start nothing happens. The cycle’s LED is still lit up but nothing. When it is operating correctly once you hit start the LED will start blinking until you close the door.
So I’ve read the forums but can’t find an answer to figure out which part I need or how to diagnose the problem further. It seems it’s either the user interface, the ribbon cable connecting to the electronic control assembly or the electronic assembly itself. Any ideas?
And then if it is one of them how do I open up the panel? Thanks in advance for any help.
