Kitchen aide electric dryer tripping breaker
last week dryer was tripping the breaker and when i took off the back panel i found the wires to the thermal switch and switch melted so i replaced the swicht and thermostat and connectors, but it is still tripping the breaker, can any one help?
Here are yoiur parts
Replacement parts for WHIRLPOOL KEYS750JQ0 | AppliancePartsPros.com
Here is the wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%203406699.pdf
Knowing which thermal switch you replaced may be helpful.
Does sound like you have a grounded element at least that is where I would start.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it.
