Kitchen Aid Wiring Harness
I have a fairly new dishwasher and a mouse has chewed thru some wires. From the look of it, all of the wires are included in a single harness…with plainly identifiable plugs and also color coded. I think the best fix is to replace the wiring harness for the entire unit…but I’m having trouble finding the harness to purchase. Is this part available?
C Morgan,
Yes you are probably, correct.
I too would replace the complete wire harness.
Unfortunately, I have no parts list or part number for the wire harness, either.
You may want to contact the manufacturer, they would be more able to assist you there.
Good Luck,
