Kitchen aid wall double oven error codes F1E0, F2E1
Brand: Kitchen Aid
Model Number: KODE300ESS04
Main Symptom: Error codes F2E1, F1E0, moisture on face of control panel
What happens & when: After baking in the upper oven for at least a half hour, control panel starts beeping with error codes and shuts off. control panel inputs are blocked. Moisture on face of control panel
Error Code (if any): F2E1, F1E0
Parts or tests already tried: Control Panel repaced, problem returned
The moisture getting on the control panel is the cause of the codes. This is a design issue that the manufacturer never resolved. Their suggested solution is to make sure that any high moisture content items being cooked in the oven be covered, and that the oven door be only fully opened when checking items in the oven cavity, do not just crack the door open a little if checking something. Otherwise, there is no permanent fix, repair, or modification for this issue.
Thank you for your prompt response! I suspected that. I think that another solution is to bake items that produce a lot of moisture in the lower oven only. The vent for each oven is at the top of each oven and it feeds directly to the bottom of the control panel on the upper oven. That is a very poor design.
