Kitchen Aid:Switch Panel Membrane or Control Board?
Hope someone can help with this.
Kitchen Aid KUDR24SEWH2 - stopped in mid cycle. Dishes were clean, but wet when door opened several hours later. Standing water in bottom.
No lights or functions when I tried to start it again.
Thought maybe switch panel membrane or control board ?
Replacement parts for WHIRLPOOL KUDR24SEWH2 | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%209743409.pdf
Could be a number of things but the Thermal Fuse would be at the top of the list. See Item 22 in Section 2. Be sure to use the new harness if this is the problem.
Check it with a meter.
I would also check that the vent actuator and the dispenser are not shorted before replacing the fuse.
